Results 1 to 3 of 3
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Richard Rushing's Avatar
    Richard Rushing Guest
    Default Re: Discolored water
    Lack of use is the cause....
    Flush the water heater tanks and lines before use (several times).
    But.... there is always the possibility of having a root problem having damaged the supply lines that allow dirt to leach into the lines.
    If it runs for a while and clears... no problem-- do the flush thingy.
    Cause - unknown
    Concern - yes, if you don't note it on report
    Defect - contractor should figure that out
