Results 1 to 3 of 3
Thread: Discolored water
09-29-2007, 07:28 AM #1
Discolored water
09-29-2007, 09:51 AM #2
Re: Discolored water
Lack of use is the cause....
Flush the water heater tanks and lines before use (several times).
But.... there is always the possibility of having a root problem having damaged the supply lines that allow dirt to leach into the lines.
If it runs for a while and clears... no problem-- do the flush thingy.
09-29-2007, 04:07 PM #3
Cause - unknown
Concern - yes, if you don't note it on report
Defect - contractor should figure that out
