03-21-2013, 06:43 PM #1
Domestic water supply system & Pressure Relief Valve
A pressure relief valve (or expansion tank) is required if the home has a pressure regulator or other device that closes the loop...does the pressure relief valve at the tankless water heater meet that requirement or must another PRV be installed at an exterior location?
03-22-2013, 05:30 AM #2
Re: Domestic water supply system & Pressure Relief Valve
Two different beasts Marc. Here is some good info on expansion devices. I almost always see them installed just above water heater on the cold water supply line. Their main job is to protect against thermal expansion as water is heated. Hope this helped. Thermal Expansion - Learn About - Watts
or http://www.aohomeinspection.com/pdf/...on-control.pdf
03-22-2013, 09:23 AM #3
03-22-2013, 01:41 PM #4
