Results 1 to 13 of 13
Thread: t in tprv
    Jul 2010
    Summerville, South Carolina
    Default Re: t in tprv
    Likely, the device that is barely visible on the cold water inlet side is a Pressure Relief Valve.
    When water pressure exceeds a set point it opens. The water is then exhausted into the discharge pipe of the TPR valve. This is not allowed because the TPR discharge is not allowed to have a Tee installed in the line. Otherwise it should not cause a problem. But it is wrong.
    Jul 2010
    Quote Originally Posted by Ray Thornburg View Post
    Only a slightly better view
    Does not alter my first opinion.
    Not allowed by code.
    That said, some AHJ seem to not 'see the problem with it' and 'overlook it' (I don't want to accuse them of 'allowing' something not allowed by the code).
    Jul 2010
    Thanks guys.....my concern was not only the t but that it appeared to be connected to the water line which I had not seen before. I was wondering if you guys had any info on the that type of pressure relief valve that rick mentioned? Thanks....
    That pressure relief valve on the cold pipe is a cheap alternative to an expansion tank, AFAIK.
    I have a better pic of one somewhere, but try a google search. The discharge pipe from that valve can just drop into the drain pan, or into a bucket, because very little water comes out of it under normal conditions. I am not a plumber.
    Mar 2008
    Charlotte NC
    My neighbor, retired plumber/co. owner, likes the relief valves better. He says they replace a lot of rusted expansion tanks but have not had any problems with valves. Not sure if they are any cheaper either.
    Jul 2010
    I was wondering if any product literature was available? I can't find any for this use.
    Mar 2008
    Charlotte NC
    Google thermal expansion device for water heater
    Jun 2012
    Texas
    What about the galvanized water lines? I always write them up as they eventually become a problem. Looks like you can already see some rust at the connections but its hard to tell.
    Jul 2010
    Quote Originally Posted by Jim Starkey View Post
    Good eye.....yes I mentioned the corrosion in my report along with three other things.......I wanted to thank everyone for their help......
    Dec 2007
    Holladay, UT
    I believe the name for this type of device is a "thermal expansion ball valve". I see them here all the time, occasionally I see them running constantly when they should only release when pressure increases from thermal expansion and that is usually accompanied by high water pressure with no or broken pressure relief valve on main service line. They can also serve to keep the floor drain trap primed. Link follows: http://media.wattswater.com/PG-ThermExpansion.pdf
