Results 1 to 21 of 21
    Matt Fletcher's Avatar
    Matt Fletcher Guest
    Default A realtor told me....
    That this type of plumbing connection line should be written up as a defect because they fail. About 90% of newer homes have these type of connections and I have never written them up. Maybe I was absent that day in home inspector school. Anyone else write these up??
    Default Re: A realtor told me....
    Quote Originally Posted by Matt Fletcher View Post
    When they fail I write them up, (or when improperly installed).
    Aug 2011
    I have never seen them "fail". I have seen some poorly installed and leaking. I write them up if there is a problem.
    Nov 2007
    Chicago
    That type of supply is pex. Around me in homes they are allowed, but in commercial applications they are not allowed. Chicago allows them as long as the building is less than 3 stories and houses no more than 3 families.
    I would tell the realtor, then you would have to write up the new Delta faucets, since they are building their faucets with built in pex supplies.
    Mar 2010
    conyers, ga
    They are the worse ones, many do crack after some time. Personally, several in my house cracked, I ended up replacing all with the stainless braided type and never had a problem since.
    I have seen more problems with homes on municipal water source around my area, no expansion tank, suspect back pressure buildup from water heater causing most of those bursting, but still, see more of this type cracking than any other types, but are allowed in many areas.
    Nov 2010
    Safety Harbor, FL
    Maybe she thought it was polybutylene opposed to Pex?
    Oct 2008
    Portland, OR
    Are we sure it's PEX? Even 3/8" PEX is pretty difficult to bend like that. Would have to have pretty thin walls.
    Apr 2011
    Hermann, Mo
    Cool Re: A realtor told me....
    I don't write them up unless leaking . I have had these in my house for 16 yrs no problem yet
    Those 3/8" supply risers are pvc and are made specifically for that use. I have never seen one "fail", I have seen them "leak" at the valve end because of improper installation (i.e., not inserted into the nut far enough, using a brass compression ring instead of the nylon ring, not installing the required internal insert, etc.).
    Al least that is what I have seen, and not seen (no "failure") in my rather limited lifetime ...
    Nov 2007
    Chicago
    I'll go with your evidence ... however, when I have purchased those ... er ... ones that "look like" those ... the labels always said "PVC" on them ... maybe I was getting cheap designer knock-offs?
    So what is the count now?
    4...5?
    Aug 2011
    Maybe PEX comes in PVC colors, cuz mine sure look like pvc too.
    Nov 2007
    Chicago
    Well lets look at this another way. Is PVC allowed for water service? In Illinois you can use PVC for cold water distribution, but hot water requires CPVC. So if those plastic supply lines are not pex and are indeed PVC then they do not meet the code for the hot side of the faucet.
    Aug 2011
    Quote Originally Posted by Ron Hasil View Post
    I don't disagree, but I'm just saying that I have some faucet hook-ups that sure look like pvc. BTW, if I am installing those fixtures, I rarely use the enclosed plastic tubing and use flex hose connections.
    Those pipes are grey plastic. I think we can agree on that much.
    The realtor has been told that grey plastic is bad news. End of story.
    Those grey plastic hookup pipes are in millions of home doing the job just fine.
    PVC is typically hard plastic, PEX is usually soft plastic. I accept PEX as the best answer.
    Nov 2007
    Chicago
    Quote Originally Posted by Kevin Wood View Post
    I recommend a change out to braided steel flex almost all the time.
    This one I would do the same as the picture says a 1000 words.
    Also in my neck of the woods only CSA approved ones.
    I have seen more flooded homes due to the braided steel supplies failing. The braided part is just covering a rubber hose. I prefer the chrome plated copper supply lines. Nothing beats a good hard piped water supply.
    Yeah, I can only remember when
    May 2012
    VA
    While that is a sloppy installation it is still a legal one. If you read the writing on the supply tube you will see that it clearly says PEX. Those supply lines do have the cone head molded on them and should outlast the faucet they are attached to. The PEX lines that have the slip on cone head should never be used. They can "and do" come off under pressure with undesirable consequences. FYI: Another note is that the ferrule used on the valve end should be the nylon or plastic ones that come with the PEX tubes instead of the copper ones that will get cocked in the fitting and cut the PEX line causing a leak at that connection. Still if it isn't leaking at the time of the inspection, it's not an issue
    that needs to be addressed.
    - - - Updated - - -
    St. Louis, Mo. area.
    Quote Originally Posted by Bob Wisnewski View Post
    Bob, I think you nailed it. The realtor probably thinks it's that grey, opaque stuff (polybutylene) that her favorite H/I pointed out in an old manufactured home some years back, and now everything that is grey and opaque is suspect. But then that's why she's a realtor, and not a home inspector.
    Mar 2010
    conyers, ga
    Thinking about it most of the ones I have seen fail were excessively bent similar to the ones pictured or worse and had cracked in a bend area, but have had a few fail, of course were ones installed around the late 80's.
