    Jun 2011
    Mississippi
    Default Alternative use for a down draft exhaust vent duct
    Hi everyone,
    I had a client ask me the other day if he could use an existing downdraft vent duct that runs through a concrete slab on grade to route a propane gas line in order to switch from electric cook top to a gas cook top in an island. I was under the impression that he wanted to use it as a pipe chase in stead of a ventilation duct. I later found out that he wanted to use the duct for both uses. I told him that it was unacceptable according to the current municiple code, which is 06 IRC. Was I correct?
    Thanks for any feedback.
    George Hallaron: Owner primary inspector
    Bienvenue Home Inspections LLC
    www.bienvenuehomeinspections.com
    Default Re: Alternative use for a down draft exhaust vent duct
    Quote Originally Posted by George Hallaron View Post
    Hi everyone,
    You did good!
    Honestly I would not want to have an LPG line running under a slab in a chase. If you ever had a leak and with LPG being heavier than air, you would basically have a bomb.
    - - - Updated - - -
    Jun 2011
    Mississippi
    Scott,
    Thanks for the feedback.
    Mar 2012
    Ben Lomond, CA
    As a note of clarification, a gas line under a slab for a habitation is required to be in a chase pipe that is vented to allow the gas from a leak to dissipate away from the structure. There by not building up a gas pocket under the structure. You were right to tell the client that the use he had in mind was unacceptable.
    Oct 2016
    Texas
    Quote Originally Posted by William Cline View Post
    I have the same situation, but I want to use the existing downdraft vent only for the gas pipeline. Will that still be a problem? Instead of the downdraft vent for exhaust, I plan to install the cooktop hood on the ceiling..
