    Richard Stanley's Avatar
    Richard Stanley Guest
    Default Macerating toilet system
    IRC P2723 references macerating toilet systems.
    What is that???
    Default Re: Macerating toilet system
    It is a toilet that chews up all of the crap (literally) and pumps it up into the sewer system. They are used in areas that would be difficult to install plumbing lines. Also used in temporary situations. I found one a few years back, they have a box with all of the goodies in it behind the bowl. This is the link to the brand that I found a few years back. Saniflo macerating toilets: install a bathroom in the basement or any small space
    Thanks Scott.
    The info says " increase the value of your house." Do you think???
    Kind a like a garbage disposer, huh!
    Jun 2009
    Melrose, Massachusetts
    I just saw a Saniflo SaniCompact 48 macerating toilet yesterday on the first floor of a house. Makes you wonder why they didn't install a standard toilet... Drains with a 1 inch drain pipe. Worked fine with just water, and I could hear the macerator at work. The bathroom sink also drained into it, and under the sink was an air admittance valve.
    I recommended they look for local permits, as there were lots of things in this house that looked like amateur work. Company literature here: Saniflo Sanicompact 48 All-In-One Macerator and Toilet
    Donald Bissex
    www.mystichomeinspection.com
    Easier to run a 1" drain with less incentive to cut big chunks out of the floor joists? - That's a good thing.
