    Mar 2011
    Corinth, NY
    Default Gas hot water heater draft hood
    There is no draft hood on the gas hot water heater, but is direct plumbed to the vent pipe which leads to a steel b vent chimney through the roof. Is this ok?
    By the way, could someone tell me how to resize my photo's as I can't upload them as it is to big.
    Default Re: Gas hot water heater draft hood
    While most water heaters do have a draft hood, direct vent water heaters do not.
    https://www.google.com/search?q=dire...hrome&ie=UTF-8
    https://www.google.com/search?q=dire...w=1510&bih=775
    Mar 2011
    Corinth, NY
    It is a mechanical draft.
    Mechanically vented gas appliances can NOT be vented into 'B'-vent as it is not designed or approved for positive vent pressure. Yes, please post pics when you can along with make and model. Some WHs are designed as natural vent but guys install aftermarket power vent kits, which are not approved unless tested and listed for that model appliance and vented with listed gas vent for positive vent pressure or other material such as PVC if specified and approved by the mfr.
    Oct 2008
    Vilonia AR
    Quote Originally Posted by Russell Melville View Post
    To resize pictures, I use "VSO Image Resizer" program, which I downloaded. I cannot remmeber if I had to pay for it, but I thinkit was free.
    Ingleside Illinois
    VSO is free it comes with windows 7 and above
    Jun 2012
    Texas
    any back pressure from the roof top will blow out the pilot light if there is one.
