11-05-2013, 12:58 PM #1
gas shut off inside furnace cabinet
This seems obviously wrong, but I don't think I've ever seen it before so never asked.
11-05-2013, 01:25 PM #2
Re: gas shut off inside furnace cabinet
Hi John. Good to see you're back at inspecting.
I've seen this same setup a few times and also called it out as incorrect.
11-05-2013, 02:04 PM #3
11-05-2013, 03:01 PM #4
It's wrong.
11-05-2013, 06:57 PM #5
Of course, that's not the only problem in there...
11-06-2013, 06:34 PM #6
I'd write it up as a hazardous defect. The majority of the time I test those older brass valves they leak.
