Results 1 to 9 of 9
    Las Vegas, NV
    Default Dangerous Water Heater
    Ran across this unit the other day. At least the house was vacant so no one was using it then. Note the melting plastic collar around the hose bib and soot particles all over the top of the heater. Hard to imagine that much heat escaping from a covered front type heater.
    Beacon Inspection Services
    Like Beacon On Facebook
    Mar 2012
    Lansdale, PA
    Default Re: Dangerous Water Heater
    Quote Originally Posted by Bob Knauff View Post
    Seeing the flex vent pipe makes me want to see how this is vented.
    Jul 2010
    Kansas City Missouri
    From the soot I’d say there is some serious incomplete combustion going on in addition to the backdrafting. Since that's a FVIR type heater and the burner cover and window appear intact, I wonder how the flames and/or heat could be escaping from there?
    Galen L. Beasley
    Inspections Supervisor
    Housing Authority of Kansas City MO
    Quote Originally Posted by Galen L. Beasley View Post
    I suspect this has been tampered with. Note the missing wire on the thermo switch
    Likely the intake has restriction
    This caused overheating in the chamber, which tripped the thermo switch.
    They pulled the cover off trying to "fix it" and probably did not re-install (or installed incorrectly) the cover gasket
    They did not find what was wrong so they disconnected the thermo switch.
    If the thermo switch was working, it could not have gotten hot enough to melt the plastic.
    Of course, I'm just speculating, but I'll bet I'm real close.
    Jul 2010
    That makes sense Rick. I would be curious to see what kind of CO reading you would get at the flue.
    Galen L. Beasley
    Apr 2008
    Western Massachusetts
    Improperly.
    Knoxville, TN
    That vent might be just fine. There is at least one manufacturer that makes one that looks like a dryer vent, but is approved.
    Apr 2008
    It may be constructed of approved materials, but that vent is most certainly not fine.
    Quote Originally Posted by Corn Walker View Post
    ... but that vent is most certainly not fine.
    That vent may be fine in if the water heater is in an approved location for the use of that vent.
