Results 1 to 12 of 12
10-16-2007, 07:27 PM #1
BASEMENT PUMP USED for WASHER MACHINE
I came across this today and just wanted to get some feedback on how to report it?
10-16-2007, 07:47 PM #2
Re: BASEMENT PUMP USED for WASHER MACHINE
Robert,
Improperly wired dryer connection.
Improper Washer drain.
Improper Dryer Exhaust.
Evidence of water intrusion on left side of basement window and on right side crack.
I'd start with that
Buy the way Robert is the Blue Bird School Bus manufacturing facility still next to The Roper Range Assembly Plant?
Last edited by Billy Stephens; 10-16-2007 at 07:58 PM. Reason: changed washer to dryer connection
10-16-2007, 07:56 PM #3
Thanks Billy,
I appreciate the quick response.
10-17-2007, 04:28 AM #4
Billy,
I don't see where the dryer would be improperly wired and is that a sump pump?
10-17-2007, 04:43 AM #5
10-17-2007, 04:54 AM #6
Billy,
So what type and size of wiring should have been used?
10-17-2007, 05:04 AM #7
10-17-2007, 05:16 AM #8
Please forgive my ignorance, I just want to be better prepared for the next go round.
10-17-2007, 05:48 AM #9
Based on the water staining running across the basement floor, I'd say that the sump pump clothes washer drain system is inadequate for the the use (it's a sump pump, not a clothes washer drain pump) and that a proper clothes washer drain system needs to be installed.
A clothes washer can dump out 20-30-40 gallons of water QUICKLY, I doubt that setup can keep up with it, hence the water running across the floor.
Don't forget about that plastic dryer vent - not allowed.
Oh, yeah, and that can holding up the trap for the clothes washer standpipe? Priceless.
10-17-2007, 05:53 AM #10
Mr. Davidson,
We all have to learn and it's an on going process.
If your are unprepared to inspect some ones home you are doing them and yourself a disservice.
Some of the issues we check are life and limb concerns.
I would not want to be responsible someones death or disablement for lack preparation.
10-17-2007, 05:56 AM #11
10-19-2007, 08:14 AM #12
