01-02-2014, 08:12 PM #1
01-02-2014, 09:45 PM #2
Re: Another - Anyone Know What This Thing Is?
I had never seen one till I saw this one. But I know what it is. It is a valve on a well water line.
You can set the valve by degrees to reduce flow. This way the pump, probably a submersible, can only deliver what you allow it to. Keeps the pump from sucking air where there is a slow recovery.
01-03-2014, 12:39 AM #3
01-03-2014, 06:50 PM #4
It obviously allows one to adjust the angle of the water coming out of the pipe!
877-466-8504
01-03-2014, 09:15 PM #5
If there is significant sediment in the well, it can be avoided by limiting the flowrate from the well. I have used this technique on a personal well, which will pump 12 gpm with lots of sediment, or pretty clean water at 2 gpm.
01-06-2014, 08:35 AM #6
