Results 1 to 2 of 2
01-06-2014, 04:43 AM #1
Looking for a solution to freezing pipes
My synagogue has an annual issue with pipes freezing some are below slab others are on an outside wall. (this is a common problem with churches as well)
Yes I know - it never should have been done that way.
Since the building is empty for a couple of days a week chances for a freeze up increase and I have thawed them twice in the last week
I have thought about connecting a small circulating pump from the hot water feed to cold water with an isolation valve (connecting this permanent, possibly with temperature controls) but I do not know if this is legal also need to find a small pump something around 1/10 gal per minute.
I am also open to some other ideas
01-06-2014, 05:51 AM #2
Re: Looking for a solution to freezing pipes
This may offer a solution, short of major plumbing upgrades.
Hot Water On Demand, Hot Water Pump, Circulation Pump: COMFORT | Grundfos
http://ca.grundfos.com/content/dam/G...mfort_Pump.pdf
See page 33 - Comfort Systems
http://ca.grundfos.com/content/dam/G...02_UP10-16.pdf
