    Clay White's Avatar
    Clay White Guest
    Default WH vent to draft hood connection
    Default Re: WH vent to draft hood connection
    Quote Originally Posted by Clay White View Post
    I just can't put my finger on it, but the wh vent to draft hood connection looks wrong, or am i crazy? Is there a problem?
    (note: insulation clearances are wrong, I know!)
    Clay,
    The first section of vent pipe is a 90 degree elbow that has been straightened out.
    Looks funny,Sloppy, Lazy but no problem I know of it's rated vent.
    Where is the water cut off for wh?
    Kevin Barre's Avatar
    Kevin Barre Guest
    Clay,
    Right there on the inlet to the right opposite the flue. Where the break in the insulation is.
    Connecticut
    The draft hood has a tapered end for a reason, right. That is so you can shove that sucker right down snug and screw it togeather. Neither of which they got right.
    Needs a single-wall to b-vent adapter at the draft hood I do believe.
    Kevin Barre Guest
    I can't see a problem based on this photo. So long as the inner liner of the flue sits properly on the diverter, it looks OK to me.
