    Denver, Co
    Default Problems with Water Pressure Gauges
    I've used numerous different manufacturers of water pressure gauges but continue to have the same problem. After I use it a few times, the gauge gets stuck at between 40 and 60 and will not reset. Currently, I am using Rainbird gauges and have now taken back 5 over the last 3 months. Does anyone have any recommendations? I'm in Denver, so we use frost free faucets. I wonder if air is causing the problem.
    Default Re: Problems with Water Pressure Gauges
    Quote Originally Posted by Ron Tipton View Post
    I buy the liquid filled (Glycerin?) from professional equipment (can't recall the brand) for around $25 each and have few problems. You MUST protect from freezing though. Take them inside with you each night during cold weather.
    Sounds like the are freezing.
    Denver, Co
    It never occurred to me that they might freeze causing the problem. Great advise! I'll bring them in.
    Thanks.
    Thanks.
    Just keep them with your brass monkeys.
    877-466-8504
    Mar 2011
    Lombard, Illinois
    Hi Ron,
    I had the same problem and was told not to leave it my truck over night in the winter.
    Fidel F. Gonzales
    RELIANT INSPECTION SERVICE
    http://www.reliant-corp.com
