Results 1 to 11 of 11
Thread: Can you join PVS to ABS
04-03-2014, 01:17 PM #1
04-03-2014, 01:21 PM #2
Re: Can you join PVS to ABS
Not like that you can't. Threaded fittings OK. Glued not OK, Different plastic.
I've seen more leaks from pc to pc than 've seen leaks from that type of connection though>
04-03-2014, 01:35 PM #3
Here is the stuff..Oatey 4 oz. ABS to PVC Transition Cement-309003 at The Home Depot
It was a 15 second Google search.
04-03-2014, 01:43 PM #4
04-03-2014, 04:14 PM #5
It's not allowed inside the house according to the National Standard Plumbing Code
04-03-2014, 05:00 PM #6
The IRC does not even permit its use there: (bold and underlining are mine)
- P3003.2 Prohibited joints. - - Running threads and bands shall not be used in the drainage system. Drainage and vent piping shall not be drilled, tapped, burned or welded.
- - - The following types of joints and connections shall be prohibited:
- - - - 1. Cement or concrete.
- - - - 2. Mastic or hot-pour bituminous joints.
- - - - 3. Joints made with fittings not approved for the specific installation.
- - - - 4. Joints between different diameter pipes made with elastomeric rolling O-rings.
- - - - 5. Solvent-cement joints between different types of plastic pipe.
- - - - 6. Saddle-type fittings.
and
- P3003.18.4 Plastic pipe or tubing to other piping material.
- - Joints between different types of plastic pipe or between plastic pipe and other piping material shall be made with an approved adapter fitting. Joints between plastic pipe and cast-iron hub pipe shall be made by a caulked joint or a mechanical compression joint.
04-03-2014, 05:51 PM #7
Yes you can glue ABS to PVC, If you use a transition cement that's specifically designed for joining ABS to PVC. The glue is green, this how you can identify if the proper type of glue is used at connections. The brand "Oatey" makes it. The glue is formulated so that it melts and bonds both types of plastic. I am not sure what the exact code states. When I first seen this last year in a new development I called the city inspector. He told me that it's approved as long as they use the proper type of glue, said it should always be green. Oatey 4 oz. ABS to PVC Transition Cement-309003 at The Home Depot
04-03-2014, 07:19 PM #8
04-03-2014, 08:47 PM #9
Codes are dependent on your location. Here in MN the green glue isn't approved so no glued connections between ABS and PVC. You need to check your local codes for approval.
04-04-2014, 12:39 PM #10
04-06-2014, 10:52 PM #11
Ren...the code reference that Jerry made (and specifically #6) is found under Section 707.1 of the 2012 NC Plumbing Code (as well as last several cycles).
Dave
