Results 1 to 9 of 9
	04-17-2014, 12:21 PM #1 What the freak is this they rigged for the well What the freak is this they rigged for the well
	04-17-2014, 07:06 PM #2 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellWater damper to lesson well pump induced water hammer.
	04-17-2014, 09:36 PM #3 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellIt is a trap. Maybe somebody's idea to catch sand in the well water.
	04-18-2014, 05:20 PM #4 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellRedneck at work.........probably a very good reason and a poor solution.
	04-20-2014, 05:07 AM #5 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellOnce I gits enough iron in that thar trap I kin melt it down and make me an anvil.
	04-20-2014, 05:21 AM #6 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellLooks like a home owner iron precipitator system.
	04-20-2014, 07:37 AM #7 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellCome on guys ... they needed another couple of pipe hangers and didn't have any, so they supported it from the ground.
 Of course, though, with all that upside down with the paper facing exposed insulation there for a fire ... maybe the intent was to hold an extra supply of water to help put the fire out ...
 That's all PVC and PVC should be there for supply anyway.
	04-20-2014, 07:55 AM #8 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellNot a defect, but something that I comment on when I see it.......any exterior water spigots on that house are using filtered water. In other words, watering the garden from a spigot mounted on the house will be using filtered water which dramatically shortens the life of the filter. On my own house, I replumbed the spigots to use unfiltered water.
 Iron traps are not something done here, but if that is the purpose of that loop, then how would one clean that contraption?
	04-20-2014, 02:25 PM #9 Re: What the freak is this they rigged for the well Re: What the freak is this they rigged for the wellThe pre-filter should be more than adequate to remove any sand that is in the well water.
 If there is sand its usually an indication the pump intake is to close to the bottom of the well.
