Results 1 to 9 of 9
Thread: strap or p trap
07-25-2014, 10:44 PM #1
strap or p trap
I found this today but i am unsure if its a p or s trap. I have been researching and found contradicting info.
Can somebody please explain. Thanks much.
07-26-2014, 04:55 AM #2
Re: strap or p trap
Because there is not a trap arm, it is an S trap.
Also trap allowed is between 2-4"
07-26-2014, 07:16 AM #3
Re: strap or p trap
Neither.
It looks to be what is called "crown vented" - the minimum trap arm length (as I recall) is two times the pipe diameter, that looks to be shorter than that.
The definition of crown vented is slightly different than the above, but the above is close.
07-26-2014, 07:30 AM #4
07-26-2014, 07:51 AM #5
07-26-2014, 08:01 AM #6
Re: strap or p trap
This shows a crown vent (p19)
http://www.plumbingpros.com/pdf/dwvents.pdf
07-26-2014, 08:16 AM #7
Re: strap or p trap
Another example
http://www.ilga.gov/commission/jcar/...ZZ9996deR.html
07-26-2014, 08:21 AM #8
Re: strap or p trap
Thanks to all. It very much confirmed what i thought as well as giving me more information to learn to help improve my inspecting skills. Thanks!!
07-31-2014, 03:43 PM #9
Re: strap or p trap
As said in 1st reply, the maximum trap seal is 4" deep. That's measured from the top of the return bend on the bottom of the trap to the weir (where it overflows into the (too short) trap arm). This one appears to be more than 8" deep.
