    Mar 2010
    Ocala Florida
    Default Double trapping at kitchen sink
    Is this considered double trapping and is it allowed? Thanks
    Default Re: Double trapping at kitchen sink
    Quote Originally Posted by mark petty View Post
    Yes, No
    Swivel the first trap 90% so it is horizontal.
    Mar 2010
    Ocala Florida
    John, Rick
    Thanks for your quick replies.
    Oct 2010
    Luxemburg, Wisconsin
    A garbage disposal should have its own trap (which it has) but it should be connected to the drain downstream of the sink trap.
    Tabb Jensen's Avatar
    Tabb Jensen Guest
    Amateur work - Doesn't understand the purpose of the trap is to stop sewer gas, not catch things that fall through the drain. The lower one is all that is needed. The dishwasher is usually plumbed into the disposal - that's the purpose of the nipple above the drain on the disposal. Although it has a redundant trap (double -trapped) - This system looks safe and workable.
    Apr 2014
    FL, TX
    Quote Originally Posted by Tabb Jensen View Post
    The trap at the disposal is reversed left to right as we look at it. This means that the disposal will hold water in it (centrifugal force is sending it through the trap when the disposal is used, but water will fill the disposal before one runs it). This is an incorrect installation and not considered correct. If it was below just a sink it would function but hold more water than desired or needed and could leak more easily.
    As the trap is used to stop sewer gases only one trap is necessary technically. The disposal can run to the sink down pipe and then to a single trap. This means that a "divided end outlet T" is used in the assembly. If the disposal becomes old and does not chop to a small enough particle size or hair (corn silk) passes through it may clog the divided T. Without a divided T the water could easily pass from sink to sink, but the sewer gasses are still blocked.
    Replacement with a proper functioning disposal is advised in that condition. OR one could install two P traps. The preferred method for two traps is to place a Wye at the wall and then run two separate drain systems to the Wye instead of a trap to the down leg of the sink and then another trap below.
    Except for the reversed condition of the disposal's trap at the disposal causing back up into the disposal everything should be ok, just not as "preferred".
