Thread: proper trap
08-29-2014, 10:26 PM #1
proper trap
Shouldn't the horizontal arm of this trap be longer? Can you tell me what kind of dimensions i should be looking for?
08-30-2014, 04:28 AM #2
Re: proper trap
The arm should be at least 2 times the width of the pipe.
08-30-2014, 10:16 AM #3
08-30-2014, 10:50 AM #4
Re: proper trap
Looks like it meets that, but Loren brings up an excellent point with short trap arms:
While a long end into the slip joint fitting will not fully block off the vent (it will block off the drain to the same extent), it will definitely block off a good portion of the vent (as well as the drain).
08-30-2014, 11:03 AM #5
Re: proper trap
Soooo a plumber is needed right along with every other train possible for this house.
- - - Updated - - -
As a side note, I am SOOOO over country houses.
The realtor wasn't exactly sure that the house was even finaled. The crawlspace was a HUGE hazmat situation. Dead rats, mice, DROPPINGS EVERYWHERE, they also had plastic under the floor to support the insulation and that was FULL FULL FULL of droppings.
I am thinking about just burning the clothes.
08-30-2014, 01:08 PM #6
Re: proper trap
Whoa back. The trap is not textbook correct but I would not be so quick to condemn the plumbing over that minor detail. Has it leaked and caused problems?
OK the house has a rodent issue. Millions of houses do. Learn to put things in perspective or you will be twiddling your thumbs on the couch.
