Results 1 to 10 of 10
    Sky Jones's Avatar
    Sky Jones Guest
    Default sewer plug of sorts??
    Hello All
    I have never seen a plug/ blockage for an unused sewer line. Does anybody know what it is?
    Inspection Referral SOC
    Washington State
    Default Re: sewer plug of sorts??
    It's a temporary test cap that needs broke out and removed. A threaded fitting with clean-out cap should be installed. I see these in the crawlspace quite often, some times I find them left on at the roof vent pipes.
    Sky Jones's Avatar
    Sky Jones Guest
    So this is not some kind of insert plug? I am used to seeing caps but thought maybe I had missed a new kind of cap.
    Sky Jones's Avatar
    Sky Jones Guest
    Caps, who needs caps. Looks good to me, (SARCASM) This was the first house yesterday.DSCN3851.jpg
    The waste lines were made of PVC, ABS, Cast iron, and Copper.
    Loren Sanders Sr.'s Avatar
    Loren Sanders Sr. Guest
    Quote Originally Posted by Sky Jones View Post
    What an expensive copper cap.
    May 2009
    Washington State
    They forgot to fold it over, pinching it off isn't as effective.
    Nov 2010
    Red Deer, Alberta
    Quote Originally Posted by Jim Hintz View Post
    It is soldered though, which if done well, is sufficient.
    the biggest problem visible in the photo is the tee-wye on its back, and the failed branch connection. (pulled right out, with no visible glue signs)
    - - - Updated - - -
    [QUOTE=David Johnston;247922] ... the biggest problem visible in the photo ...
    after looking again I see that the cast wye has a rubber (plastic) wired over it for a cap -- also a big problem...
    Sky Jones's Avatar
    Sky Jones Guest
    [QUOTE=David Johnston;247922]It is soldered though, which if done well, is sufficient.
    - - - Updated - - -
    Quote Originally Posted by David Johnston View Post
    You are very correct, I noted multiple other plumbing issues under this house.
    Me thinks Virgina R Hammond might be more than a few individuals. Just look at the two post from it and the different writing styles.... Just saying...
    Aug 2011
    Her first response reads like an automated response. I noticed that in some other posts where she has two posts back to back. Nothing wrong with her comments, just rather impersonal.
