Results 1 to 15 of 15
    Atlanta, Georgia
    Default Visually interesting plumbing
    Nine year old construction. Water heater was same age as the house.
    Plumber decided to add some visual interest to the water heater plumbing.
    Default Re: Visually interesting plumbing
    That visually interesting plumbing serves as a heat trap. Really.
    That expansion tank is improperly supported off the side of the tee fitting.
    Aug 2011
    And my understanding is that those sharp U turns slow the flow a bit.
    Not any more than any other elbow.
    Before heat traps came with water heaters, and before heat traps which come with water heaters were even thought of, and after some plumbers don't realize that those heat traps come with water heaters or are available ... heat traps had to be made with the piping - like you see there.
    Their intent is to trap the heated water from circulating up and around the hot water piping, and that upside down U does that to a great degree.
    Aug 2011
    To clarify for myself, you don't have a problem with these loops, do you?
    And btw, I wouldn't write them up as a problem, although I don't think I've ever seen this.
    Nope problem with them at all.
    In fact, if the heat trap couplings are not installed, then those made-up heat trap loops would be required.
    Jerry
    Maybe I'm wrong but I was thinking the inlet and outlet have plastic one way valves that makes the trap shown unnecessary.
    Now that the heat is trapped, they need to add the circulation pump to get the hot water flowing again.
    Jerry
    I tried to cover all the bases for the various options they may have run into, including "and after some plumbers don't realize that those heat traps come with water heaters" ...
    I didn't recognize that's what you were saying.
    Possibly because I was trying to be politically correct and not say that the plumber didn't know what they were doing
    If they had those heat trap nipples ...
    Aug 2011
    Sorry, I'm having trouble typing with all my coughing...........is this a new JP?
    May 2009
    Washington State
    Ditto on the coughing, nasty bug floating 'round the country.
    Nov 2010
    New Westminster BC
    There were traps on both the inlet and outlet pipes. On most water heaters the heat does not convect up the water in the inlet pipe probably because the inlet feeds the water down to the bottom of the tank, away from where the heat rises, so I don't think you would normally need a heat trap on the inlet pipe.
    Agree it's not a problem having traps on both pipes rather than just on the outlet pipe even though the extra trap has little or no benefit. I wouldn't comment on it in the report.
    Georgetown, KY
    People do some strange stuff with piping!
