Results 1 to 15 of 15
Thread: Visually interesting plumbing
12-18-2014, 07:02 PM #1
12-18-2014, 08:08 PM #2
Re: Visually interesting plumbing
That visually interesting plumbing serves as a heat trap. Really.
That expansion tank is improperly supported off the side of the tee fitting.
12-19-2014, 07:31 AM #3
And my understanding is that those sharp U turns slow the flow a bit.
12-19-2014, 08:25 AM #4
Not any more than any other elbow.
Before heat traps came with water heaters, and before heat traps which come with water heaters were even thought of, and after some plumbers don't realize that those heat traps come with water heaters or are available ... heat traps had to be made with the piping - like you see there.
Their intent is to trap the heated water from circulating up and around the hot water piping, and that upside down U does that to a great degree.
12-19-2014, 09:31 AM #5
12-19-2014, 10:10 AM #6
12-19-2014, 12:55 PM #7
Jerry
Maybe I'm wrong but I was thinking the inlet and outlet have plastic one way valves that makes the trap shown unnecessary.
12-19-2014, 04:51 PM #8
Now that the heat is trapped, they need to add the circulation pump to get the hot water flowing again.
12-19-2014, 05:29 PM #9
12-19-2014, 06:33 PM #10
12-19-2014, 06:38 PM #11
12-20-2014, 08:07 AM #12
12-27-2014, 08:34 AM #13
12-27-2014, 03:31 PM #14
There were traps on both the inlet and outlet pipes. On most water heaters the heat does not convect up the water in the inlet pipe probably because the inlet feeds the water down to the bottom of the tank, away from where the heat rises, so I don't think you would normally need a heat trap on the inlet pipe.
Agree it's not a problem having traps on both pipes rather than just on the outlet pipe even though the extra trap has little or no benefit. I wouldn't comment on it in the report.
12-28-2014, 06:43 AM #15
People do some strange stuff with piping!
