Results 1 to 13 of 13
Thread: WOW!!!!!!
    Default WOW!!!!!!
    Very surprising nobody was killed in this explosion.
    Watch the video. It's eye popping.
    WATCH: Video Shows House 'Disintegrate' After Manahawkin, N.J. Explosion | Barnegat-Manahawkin, NJ Patch
    Default Re: WOW!!!!!!
    That would really have made a great video if it had been caught closer up - WOW! is right.
    "Wow!"Is right! Great safety reminder for all of us. Hope all involved can recover.
    Dec 2013
    Oklahoma
    Quote Originally Posted by Cale Cameron View Post
    I remember seeing it on the Nightly News: No one was killed, but 16 injured. They think it was a Gas Leak that was set off by a spark.
    Charles Woodie Wallace
    Top2Bottom Home Inspection LLC
    Edmond, OK
    Top 2 Bottom |
    t2bhomeinspection@outlook.com
    May 2009
    Washington State
    Incredible to say the least. I have a question just out of curiosity, here in the Puget Sound Area they allow a gas furnace to be installed in an attic space - they're installed on their side. Do any of you out there run into this and, what are your thoughts about it? Makes me wonder about seismic activity and connections nobody ever sees nor can smell.
    Jim
    Quote Originally Posted by Jim Hintz View Post
    Jim
    The furnace would be required to be designed for horizontal installation, not all are.
    Also, that sediment trap is not a sediment trap, at best it is a 'handle" to grab onto when you lose your balance.
    Mar 2008
    Charlotte NC
    Jerry, you can read the labels on the side of the unit so it has to be right....shish.
    May 2009
    Washington State
    This Bob's HVAC is the only company I see doing this. They also make or used to make the filter compartments an "off" size so you'd have to buy "their" filters.
    NoCal
    I see this often, and is a common installation. as JP said - as long as it is rated for horizontal installation. They hang from the framing typically with bolting, brackets, allthread and channel iron. Seismic should not be a problem. They are relatively light weight.
    Saves space by not being in the hall closet.
    Robin Wells's Avatar
    Robin Wells Guest
    Agreed.. and good reminder.
    Here are some still photos.
    Heroism amid chaos emerges from massive Stafford natural gas explosion | NJ.com
    mt, clemens Mi.
    Wink Re: WOW!!!!!!
    Jerry, nice catch on the wrong t configuration of the sediment trap "handle"!
    - - - Updated - - -
    Jerry, nice catch on T piping for the sediment trap!
    Sep 2008
    so so, California
    I'd say that nearly 100% of all new construction here has Horizontal furnaces. I saw 4 today..
    Jim
    May 2009
    Washington State
    Thanks to everyone that responded.
    Jim
