Results 1 to 3 of 3
04-21-2015, 02:32 PM #1
12" Metal Supply @ Top of Water Heater
I know this topic has been batted around a few times but I cant seem to find it...
Some say the supply pipes to a water heater must be metal for the first 12 inches at the top of the water heater and then can transition to other approved supply materials. Makes sense with a gas water heater due to the heat of the exhaust. Cant find a code reference specifying this. Can anyone point in the right direction?
Similar Threads:"The Code is not a peak to reach but a foundation to build from."
04-21-2015, 02:50 PM #2
Re: 12" Metal Supply @ Top of Water Heater
04-23-2015, 10:14 PM #3
Bruce...
The code reference is that the code requires you to follow manufacturer specifications.
But it's not a water heater 'thang.'
It's the plastic pipe manufacturers that require their products not be within a minimum 6 - 18 inches (varies by manufacturer) of a heat source (e.g., water heater vent). So OK for electric.
Dave
