Results 1 to 27 of 27
06-28-2015, 10:59 AM #1
Any idea what this triple gismo is?
These three thin plastic tubes or rods coming together at the black triple coupler behind the tailpiece have me baffled, and I'm hoping that someone on the forum can tell me what their function is. They were present under two of the bathroom sinks in yesterday's inspection - a 31 year old higher end home.
Thanks a lot for any help you can provide with this.
Similar Threads:Last edited by Michael Chambers; 06-28-2015 at 11:03 AM. Reason: Trying to improve title.
06-28-2015, 11:43 AM #2
Re: Any idea what this triple gismo is?
Looks like some kind of water line tap.
06-28-2015, 03:35 PM #3
Other than this strange contraption, the faucets looked like any others from above and at the water supply line areas below. There was too much stuff in the cabinets to get my head in far enough to see where the rods or tube went. I wish now that I'd stuck my camera back there and taken a couple of shots.
06-28-2015, 04:30 PM #4
On both hot and cold, cold only, or hot only?
Was there a hand held sprayer nearby?
06-28-2015, 05:45 PM #5
The faucet assemblies had two separate controls, one for each for hot and cold, and then a central spigot. This mechanism appeared to have its three long components extending up to the area of the lower portions of each of the controls and the central spigot area. Another odd thing was that this mechanism did not appear to be rigidly attached, but was easily moved back and forth. The one in the photo was interfering with the stopper bracket movement, and I easily moved it out of the way to allow the stopper to fully open.
There was no hand held sprayer. From the top these appeared to be just standard bathroom sink faucets like we see every day.
06-28-2015, 06:51 PM #6
In that case ... I have no idea why it is there.
Is it a two handle (two valves) faucet set (3 totally separate pieces) for 8" centers?
Or a two handle faucet set (one piece) for 4" centers?
06-28-2015, 07:04 PM #7
06-28-2015, 08:51 PM #8
06-28-2015, 09:40 PM #9
Those tubes or rods are not much more than a 1/4 inch in outside diameter - much too small to carry any significant volume of water. I'm wondering if this might be some kind of mixing arrangement to make sure there is at least some amount of cold water mixed in with the hot as a safety measure, but I'd think they'd do that much higher under the faucet assembly to save material, and to avoid interference with the stopper movement.
I'll email the photo to a plumber friend to see if he knows what it is.
06-29-2015, 06:16 AM #10
Maybe some type of under sink filtration system:
http://www.homedepot.com/p/Perfect-W...2?N=5yc1vZaqv5
Peak Inspection Services | Over 34 Years of Contractor Experience!
Residential Inspections | Commercial Inspections
Office: 908-750-6789 | www.peakinspectionservices.com
06-29-2015, 03:40 PM #11
It is simply the hot, cold, and outlet to the spout. I just came across one like that today. I'll try and post photos later.
06-29-2015, 04:05 PM #12
06-30-2015, 05:26 AM #13
06-30-2015, 06:42 AM #14
07-01-2015, 05:57 AM #15
07-01-2015, 08:06 AM #16
Is there an instant hot water pump at the water heater
You would see that under sinks when there is one
07-03-2015, 02:27 AM #17
They look like air lines. I'm going to take a guess and say water hammer reducer/prevention. Make Sense?
07-03-2015, 11:11 PM #18
07-07-2015, 06:51 PM #19
Looks like part of the faucet assembly to me. I have installed a few faucets with similar types of mixing valve/connectors.
07-08-2015, 07:22 AM #20
I recognize the fittings as copies commonly used in industrial hydraulics when there is a need to disassemble quickly. They will work with any material having the same O.D.. I recently had a plumber install an icemaker in my house and he used these materials.
I have never seen this tubing or fitting any larger than 3/8". Most likely will have greatly reduced flow to the fixture.
I would write this up as a material defect in materials.
07-08-2015, 11:57 AM #21
No, not a material defect.
This is a listed new assembly with manufacturers supplied connections.
Just because it is an unfamiliar product does not mean it is defective.
And just because it is allowed to be installed by the manufacturer does not mean it is a good product, just allowed.
08-02-2015, 03:56 AM #22
Were you able to determine the manufacturer of the faucet assembly? They usually have a name on them somewhere. As the piping extends into the valves it appears that it was included with the device.
- - - Updated - - -
08-02-2015, 09:13 AM #23
08-02-2015, 09:52 AM #24
Just as the post you quoted said:
Originally Posted by Jim Luttrall[/quote
The cold water from the cold supply goes to the cold faucet valve.
The hot water from the hot faucet valve goes to that connector.
The cold water from the cold faucet valve goes to that connector.
The hot and cold water are joined together in that connector (mixed together) and the outgoing water from that connector goes to the spigot of the faucet set.
That connector just combines the hot and cold water from the valves to the spigot where it is used.
08-02-2015, 10:33 AM #25
Oh, Duuuh! I've just never seen one and just figured the discharge was handled internal within the assembly. So this is probably one of those where each faucet & the spigot are all separate detached pieces. Now I get it, thanks Jerry
08-02-2015, 11:10 AM #26
08-03-2015, 01:22 AM #27
