Thread: what to call
11-19-2007, 04:07 PM #1
what to call
11-19-2007, 05:11 PM #2
Re: what to call
I can't tell from the photos, but what you describe is called " Mineral deposits".
11-19-2007, 05:20 PM #3
11-19-2007, 05:27 PM #4
Re: what to call
I may be wrong, but isn't effervescence a white powdery substance found on concrete walls (usually fuzzy looking)?
11-19-2007, 05:41 PM #5
Re: what to call
Effervescence what you get in a glass of water when you drop two alka-seltzer in it.
Efflorescence is the white powdery substance on concrete and leaky pipes. The white stuff is the minerals in the water that remain behind after the water evaporates.
Jeff - my techno-geek term for the stuff in your photo is "a leak".
11-19-2007, 07:13 PM #6
Re: what to call
Brandon,
Thanks. It always rubs me the wrong way when someone uses effervescence when they mean efflorescence. Effervescent can also be used to describe a bubbly personality.
