Results 1 to 3 of 3
Thread: Water heater Question
04-12-2007, 09:09 AM #1
04-12-2007, 10:15 AM #2
Re: Water heater Question
What does that water heater mfr. say? If it calls for a non-combustible base, then write it up. Regardless, the base must be capable of supporting the load. Figure a 40 gallon water heater full of water weighs about 400 lbs. If that water heater is sitting on 4 square feet of conventional construction rated at 40 lbs per sq. foot, then it is inadequate for the load.
Then again, with a closet, do you have your circumferential clearance required by the WH mfr? Gas or electric? Need MUA and combustion air?
What is the construction under the WH?
Any pics?
04-12-2007, 03:29 PM #3
What Bob said, with some additions.
1) How many 2x4s? Enough to make a full support under the water heater?
2) If electric, it can be set on the wood, if the wood meets what Bob said and/or 1) above.
