09-13-2016, 10:15 AM #1
Water heater PEX CPCV connection.
Appears to be glued.
09-13-2016, 10:48 AM #2
Re: Water heater PEX CPCV connection.
Yes it does.
Question: Where is that going to/coming from? It goes up to what looks like a male hose thread adapter which has an elbow connector screwed onto it with a black pipe connected to it?
There are also combustible material being too close to the B-vent/draft hood too - that foam insulation is combustible and needs to be 6 inches from that draft hood.
09-13-2016, 11:17 AM #3
09-13-2016, 12:22 PM #4
What is the approved discharge drain line material for it?
I do not believe CPCV will bond with PEX in a pressure line. What do you think?
Section P2906 Materials, Joints and Connections
(the see the following sections - too much to type)
- P2906.9 Plastic pipe joints
- P2906.9.1 Solvent cementing
- P2906.9.1.2 CPVC plastic pipe
- P2906.9.1.5 Cross-linked polyethylene plastic (PEX) and its two subsections Flared joints and Mechanical joints
09-13-2016, 12:48 PM #5
I am looking at this on my phone and cannot see it that well. ls that coming from the TPR valve? Regardless, it looks like a DIY mess.
09-13-2016, 08:08 PM #6
Solvent-based glue will soften the PEX tubing and the joint will not hold.
09-16-2016, 05:10 AM #7
There's no reason they couldn't have continued that small black line all the way to the floor drain. Was there a floor drain? Here is the spec sheet for the BRV. By the way, I see these leaking a lot. They are designed to relieve pressure from thermal expansion but if you see it running constantly it is broken. I include this in my reports so the clients can monitor it.
http://media.wattswater.com/es-BRV.pdf
http://acloserlookslc.com/
