Results 1 to 9 of 9
Thread: New to me
02-17-2017, 06:29 AM #1
New to me
Crimped copper fitting plumbing connection. For hot water supply. Only one crimp. Everything else soldered.
First one.
02-17-2017, 07:27 AM #2
Re: New to me
That looks like a version of the fittings which are soldered fittings, but which are made with that 'ring' filled with solder.
The outside of the pipe is cleaned in the normal manner; the inside of the fitting is cleaned in the normal manner; flux is applied; the fittings and pipes are assembled; then the pipe is heated at the fitting in the normal manner - but no solder is needed because the solder in that 'ring' melts and flows around the pipe and fitting, soldering and sealing the two together.
02-17-2017, 08:31 AM #3
Re: New to me
Solderless Crimping copper pipe fittings.
The fittings are flared with a rubber O ring in the flare. Unique idea.
crimp fittings kempress viega b-press conex new hand tool
02-17-2017, 09:30 AM #4
Re: New to me
Yeah, I have seen those a few times. In my area, they are used on repair jobs. I have never seen a whole house done with those. The only advantage that I can see is that the plumber can make the repair with water in the line, whereas soldering/sweating requires a dry pipe.
Viega ProPress - the original copper press fitting pipe joining system
Press Fittings
I have also seen the type that Jerry referred to. I can only imagine those are marketed to do-it-yourselfers. I can't see a plumbing contractor using them.
Pre-Soldered Copper Fittings – IAPMO Approved
02-17-2017, 10:30 AM #5
Re: New to me
Yes repair work.
Taking everything into consideration, cost and time saved, I expect this methods to become more prevalent.
I concur.
10 sharkbite fittings in a 3 sq. ft radius with pex and copper. What a report I have to write. Where's the Tylenol?
02-17-2017, 11:23 AM #6
Re: New to me
What is the problem with having 10 Sharkbite connections? They are visible to you so they are visible to the HO. They do not leak. Even if one does leak, it can be removed and replaced.
02-17-2017, 11:41 AM #7
Re: New to me
02-17-2017, 02:29 PM #8
Re: New to me
02-17-2017, 03:48 PM #9
Re: New to me
