Results 1 to 15 of 15
Thread: Plumbing vent termination
04-13-2007, 09:12 PM #1
04-13-2007, 09:24 PM #2
Re: Plumbing vent termination
A PVC cap on the lateral would be a reasonable solution at this point in my opinion.
The sweep of the "T" might encourage some moisture to accumulate in the horizontal portion of the pipe; but I would think that would not be a major issue in consideration of the fact that the vent in general is already going to be moisture laden and somewhat "stinky" if you will.
What's the big deal about a bit of stagnant water in a sewer vent environment anyway?
Other's will, no doubt, disagree.
04-13-2007, 10:01 PM #3
At least from the picture, the moisture and rain should dribble down the back side of the vent since it looks like the pipe is on a slant. Or is it the photo?
04-14-2007, 10:18 AM #4
Needs that fitting removed.
Least one day the owner awakens to a leak caused from the water which will collect in that terminated fitting.
04-14-2007, 10:28 AM #5
"Needs that fitting removed."
Admittedly, the best solution.
04-14-2007, 12:41 PM #6
Cut pipe, put straight coupling.
04-14-2007, 01:27 PM #7
04-14-2007, 06:03 PM #8
I stand corrected again. Did not think it all the way through. But if that pipe is extended 2' above the roof it would be brought down to the proper height and only need one coupling.
04-14-2007, 07:08 PM #9
04-14-2007, 10:35 PM #10
Maybe its the angle of the photo, but isn't that pipe on an angle going through the roof?
Shouldn't that penetrate the roof more or less level (up and down) reason being, the angle of that pipe going through the roof is a little odd for the lead boot that is going over it isn't it?
Pipe looks to me like it is following the angle of the roof instead of being straigh up and down.
Is this a problem?
04-15-2007, 07:57 AM #11
For me, I'd leave the decision up to a licensed plumber.
07-17-2008, 02:06 PM #12
I found this interesting item today. It is the house sewer vent for a septic system in a very small town. The house is over 100 years old and the drain system in the house works like a charm. The house only has 1 bathroom so I had all faucets on (including the tub) and then flushed expecting an overload. Suprise!!! No problem, even adding the kitchen drain.
I don't think it would pass any kind of a code, but how should it be written up?
My only beef with it is its location during the winter for snow buildup as it is only a few inches off the ground.
By the way, there aren't any openings within 10 feet in any direction and I didn't smell it at all during the inspection.
07-17-2008, 05:35 PM #13
Looks like a frsh air intake to me.........but what do I know, you saw it, how did you determine it was a sewer vent?
07-17-2008, 05:59 PM #14
"Assumed" because there is no other vent on the roof or in the attic for the septic tank. It could be a fresh air inlet because the septic system is a new style aerated system, but I'm not a septic system expert. I just have one of those systems outside my dining room window. Maybe I will return and cover that vent then go inside and check the drains.
07-17-2008, 06:11 PM #15
Just listen at the pipe while the drains are in use. It should be pretty easy to confirm this is the vent. Most of what a vent does is an air "inlet" but I don't know of a way to make this a one way vent
The aerobic systems use a pump, not an open vent.
If it is a old house, you are probably right assuming it is the main vent and it is wrong.
It may not provide much odor if there is a belly or fitting in the line creating a trap.
