Results 1 to 32 of 32
Thread: Interesting P Traps
01-09-2008, 01:48 PM #1
Interesting P Traps
I am always amused by the plumbing I find under kitchen sinks.
01-09-2008, 02:21 PM #2
Re: Interesting P Traps
Those are outstanding.
01-09-2008, 02:24 PM #3
I'm partial to the trombone one myself.
01-09-2008, 02:26 PM #4
Nice trap on the first one, it really doesn't matter if the trap is on it's side, it'll still work.
01-09-2008, 02:32 PM #5
Lee,
Not following you there.
A trap must be vertical.
Or did I miss the smiley face you intended?
01-12-2008, 04:46 PM #6
The first one is a new "Z" trap!
01-12-2008, 05:23 PM #7
Then there's the "trap-not" or, "I don't have to show you no stinkin traps!"
01-12-2008, 06:15 PM #8
And the shop-vac trap...
01-12-2008, 06:56 PM #9
01-12-2008, 06:58 PM #10
01-13-2008, 12:16 PM #11
Yeah, I forgot my smiley, I was just being sarcastic.
01-14-2008, 11:27 AM #12
Red neck ingineeering at is finest.
Great stuff,
//Rick
01-14-2008, 11:33 AM #13
You don't need a trap when you're just running the utility tub drain straight into your basement water control system.
Let the sump pump take care of it.
01-14-2008, 12:41 PM #14
01-14-2008, 07:01 PM #15
What would concern me more is the exposed splices in second picture.
01-25-2008, 07:18 AM #16
Not a material common in my area, any issues when you "mix-and-match" like this?
01-25-2008, 07:22 AM #17
Not an issue with mixing different materials, but that drain installed with that tee like it is, the disposer is going to try to pump water back up into the sink before it ever thinks of going down, and, water from the sink, if drained rapidly, could readily back up into the disposer before it goes down the bottom leg of the tee.
That tee should have been installed with the inlet/outlet on the vertical, with the disposer (or the sink) entering on the side inlet.
01-25-2008, 07:43 AM #18
Yup... that dishwasher will try and back-up the sink almost every time. That set-up is a like having a crystal ball-- easy to tell the future.
Rich
01-25-2008, 07:52 AM #19
Then there is this pretty little beauty (drum) I just found under a home two days ago. Kinda gets you all happy under the home when you see one of these because they are just too far between sightings...
Rich
01-25-2008, 03:54 PM #20
01-25-2008, 07:53 PM #21
I like the anti-rodent pie tins on the water pipes myself.
Blaine
01-25-2008, 09:28 PM #22
Blaine,
I believe those would be termite shields, assuming the pipes come up out of the ground.
01-25-2008, 09:45 PM #23
01-26-2008, 12:32 PM #24
I see a few a month in the Boston area.
I've seen lead, brass, and PVC drum traps
May be a code (?) requirement in the State of Maine. I have five of them in Bridgton. I have a seminar in Augusta next week regarding "Maines new internal plumbing code". This should be interesting!
Go Pats
02-13-2008, 01:30 PM #25
How we do it in Chicago - there were a dozen more like these at this morning's inspection:
02-13-2008, 01:39 PM #26
Over the years, I'll bet I've found at least 20 of those leveling jacks under homes...
I guess that's what keeps the manufacturers in business
RR
02-13-2008, 02:47 PM #27
02-13-2008, 04:08 PM #28
Ooou Spare Jacks,
02-13-2008, 05:14 PM #29
Since this is evolving in great novice moments.
Here is the new floating coil box system designed to let you know if the primary gets obstructed by blowing water mist out of your registers.
02-13-2008, 06:42 PM #30
Don't know if it's clear in the picture, but that jack is supported by the table.
02-13-2008, 07:08 PM #31
Sparky the electrician invents new trap: If there should ever be a clogged drain the spark plug ignites the methane gas build-up blowing the drain line clear.
Looks like a winner to me?
02-13-2008, 08:05 PM #32
Sorry Jerry your wrong about Michael's p-trap tee. It has a divider built into the tee that stops the flow of water through the tee. The water has no place to go but down.
