04-15-2007, 08:15 AM #1
Draft hoods , combustible material
04-15-2007, 08:48 AM #2
Re: Draft hoods , combustible material
04-15-2007, 09:53 AM #3
If it's cpvc, I believe it should be at least 18 inches from the hot/cold connections at the WH.
04-15-2007, 12:03 PM #4
04-15-2007, 08:58 PM #5
It is 6 inches, just like single walled vent connector. Even if B-vent is sitting on top of the draft hood, the clearance is from the hood itself. I find melted pipe insulation all the time.
Jeff, the definition for non-combustible is ASTM E-136 or essentially Superman's cape. Do you think PVC can withstand a 1,382F vertical tube furnace without bursting into flames, crumbling apart or losing 50% weight? FYI, even Wonderboard cannot pass this test.
04-15-2007, 09:09 PM #6
So that's why your not supposed to "pull on Superman's Cape..."
So the song goes
04-15-2007, 09:12 PM #7
