Results 1 to 10 of 10
    Oct 2010
    Comer, GA
    Default why the corrosion?
    My search for a main water supply cutoff found this device (pressure regulator) with a corroded connection to copper supply line. Why is it corroded and leaking?
    Inspection Referral SOC
    Default Re: why the corrosion?
    Galvanic reaction..........dis-similar metals.
    Oct 2010
    Comer, GA
    Quote Originally Posted by David Wigger View Post
    Exactly my thinking, but what is that device?
    Mar 2011
    Scottsdale, AZ
    Quote Originally Posted by jim baird View Post
    Looks like a pressure regulator to me. Strange place for it. I'm in Phoenix though so they are almost always outside where the water main comes s into the house.
    Arizona Home Inspections & Consulting
    WWW.arizonahic.com
    Expertise to protect you and your investment. ®
    Quote Originally Posted by Greg Hammond View Post
    Looks like we are in the crawl space, so that would be the riser coming up from the meter.
    Looks like copper to a galvanized steel nipple to a pressure regulator and back to copper.
    As previously stated - galvanic reaction (rusting through) due to dissimilar metals.
    Feb 2013
    NY
    Is that a basement or crawl space ? And is that a relatively newer build ?
    Oct 2010
    Comer, GA
    Thanks for the replies.
    1975 ranch on crawl. Because it is an active leak I called for a plumber to go under there and fix the leak, and install a main cutoff on the riser.
    Sep 2013
    North Carolina
    Always interesting to see photos from other inspections.
    No floor insulation or sill plate under the floor framing?
    Keith
    Oct 2010
    Comer, GA
    Quote Originally Posted by Keith Rogers View Post
    Keith
    Wall is capped by 4" solid block, no sill plate and no anchors.
