Results 1 to 2 of 2
Thread: PVC drain lines
    Jeff Eastman's Avatar
    Jeff Eastman Guest
    Default PVC drain lines
    Default Re: PVC drain lines
    Quote Originally Posted by Jeff Eastman View Post
    Can PVC drain lines be on the ground/dirt in the crawlspace or do they have to be suspended above the ground. The lot has a great slope in front to back so the plumber just layed the drain with the natural slope of the yard to the city connection.
    They need to be properly "supported" and "secured".
    Sounds like they have the "supported" part down. If the line was buried, then it would also be "secured".
    Are you in a freeze area? If so, it needs to be protected against freezing too.
