Thread: lead drain
04-05-2007, 02:43 PM #1
lead drain
Here's a nice lead drain popped into the soil pipe. For those of you that don't see much lead, the bulge is one clue.
04-06-2007, 10:39 AM #2
Re: lead drain
Forget the lead (although we thank you for showing us what they look like, at least I do because I do not see any), you are not allowed to do that anyway.
04-06-2007, 03:02 PM #3
Re: lead drain
Thanks Jerry. The whole soil pipe was riddled with leaks anyway, so it all has to go.
04-17-2007, 03:08 PM #4
Re: lead drain
PA has some old "sxxt" that most of us never see!
Pun intended
04-17-2007, 03:11 PM #5
Re: lead drain
I see lead under bath tubs and basement laundry sinks all the time. Still see some lead supply from the street, too. That gets expensive.
04-17-2007, 03:18 PM #6
Re: lead drain
I found three lead supply pipes in the last year. More of them in the older parts of this nation.
