    Ron Bishop's Avatar
    Ron Bishop Guest
    Default Could this be polybutelyne?
    I found this supply piping material in a mobile home built in 1975. Could this be polybutelyne?
    Default Re: Could this be polybutelyne?
    That is PEX. The blue line has been bent or has a kink in it as well, also that compression fitting on the blue line might be allowed by the manufacture of the pipe. PEX can be good or it can be bad, depends on how it was installed.
    Ron, fill out your profile so we know your location.
    I'm sure it was poly at first, then the poly likely failed and it was re-plumbed with PEX.
    I'm not 100% sure, but I don't recall poly having been made in colors like that.
    Ron Bishop's Avatar
    Ron Bishop Guest
    I have to agree...thank you kindly.
    Richard Rushing's Avatar
    Richard Rushing Guest
    A 1975 mobile home... there is a high probability that there was poly-butelene originally installed.
    Just not now and at that location.
    RR
