Results 1 to 3 of 3
    Wendell Swedberg's Avatar
    Wendell Swedberg Guest
    Default Another ICC test question
    "A joint is made at the curb stop between ASTM B 75 copper line and seamless brass pipe ASTM B43. The connection is made by brazing...Does this meet code?"
    ICC says yes but again, I can not find in the code where it says this is acceptable. Any help will be appreciated!
    Default Re: Another ICC test question
    Wendell,
    You need to be more concise with your questions statements, I am assuming you are referring to the IRC.
    Review Table M2101.1.
    Sorry, Jerry.......This question is from a ICC practice exam question you get from them online.....ICC's answer was yes, in compliance, but I couldn't find the reference to back it up.
