Results 131 to 148 of 148
Thread: Toilet clearance
03-14-2010, 10:15 PM #131
Re: Toilet clearance
Wow! Just read some other posts...wow!
Let me point this one important fact out: An architect may have a 6 year degree on his wall, lots of shiny bordered certificates from high dollar schools on his brag wall. BUT, it only only takes one well trained Building Inspector with 2 certificates to shut that architects job down.
Point is, everyone makes mistakes. However, when an inspector makes one there is no financial gain...for anyone. When an architect makes one, they call it profit.
03-15-2010, 06:32 AM #132
Dan,
I also have enjoined the converations, but I take exception with some of your comments about Architects. Yes, they have been around for a while. But, my experience with Architects has been slightly the opposite than yours. Both on large and small projects that I have worked on, they tend to look at the project from the 1000 foot perspective, not down to the 1 foot level. Because of this, errors do occur----some very expensive. Some can't be corrected because of the cost involved. Or when asked about some detail, they are not sure how to answer the question and leave it to the contractor to offer suggestions. In my field I have found that we need to tell the Architect the specifications and requirements---they don't have a clue. As for relying on an Architect as much as you do to build as close to specs as possible, I can only state that if I was paying as much as you say for a piece of property and the building---I would at least want a spacious bathroom to justify my expensive lifestyle----not one the size of a Pullman's. I might want at least a 18" clearence.
Rich
03-15-2010, 09:47 AM #133
Daniel.. Due to this topic I decided to include if the toilets have proper clearance in all of my reports.. To help me prevent having a builder call and tell me "you are full of she##at, determine with out knowing me, I am "Trailer Trash" or like "Al"qaeda" . Can you provide me documenation from your Architect that I can use to not address this issue, and let it slide?
To date the only complement I've heard that a builders rep told a customer was, Oh, you had Dan do your inspection, He hates builders.
Any info would be appreciated, I sure do not want to join the Jerry's and be accused of being ignorant, being a terrorist , radical, and be guilty of spreading a virus that can inflict all my healthy customers.
www.inspectaz.com
03-15-2010, 10:51 AM #134
DMacB is likely grumpy due to more claims & bond problems again. Won't be the first cancellation notice or refusal to renew.
NBs floor area special definitions were recinded, none of his arguments or excuses "hold water", usually the case when someone is on a rant because they're "victims" of their own stupidity, laziness, or greed when finally caught and held accountable for once (or the 20th time).
03-16-2010, 09:20 AM #135
HG, of course the work I described can only be done with HOA permission, which I have.
Their bylaws state that all structural changes (which includes structural plumbing) must be done with HOA approval.
I submitted detailed plans which they approved, and now is optionally up to me to proceed with or not, and that's where I need to figure out if it can meet code or not before proceeding.
I mentioned the Chiller/Boiler pipes that I think you were referring to.
That has already been done.
As it turned out, the pipes were immediately below the slab, and not insulated, and a bad mold problem had formed over the years.
The slab above the pipes is continually wet in the summer from condensation, and w/in about a season, any carpet/liner becomes moldy.
I really had to fight w/the HOA to allow them to let me do this, but explained that it's a health risk and liability not to.
In this case, they approved it, but only under the condition that I contact their staff maintenance guy to do the work because they implicitly trust him.
My point was that he holds no licenses (not plumbing, not HVAC, etc.) and thus can not pull any permits.
So, it came down to going w/the HOA ruling, and paying their guy to do the work, or using a permitted licensed person and not following the HOA ruling.
That is the "controversy" I was referring to.
Option 3 was to not do anything, in which case I'm basically stuck with a mold health trap.
Incidentally, at this condo complex, their staff maintenance guy does all the common (HOA owned) plumbing work, with out a license or permit.
This is an old condo complex and they just don't seem to care.
The board thinks they know better than the city, and I learned to not argue with or question their decisions, even if they don't make sense.
Again, I think the best lesson learned is to get through this, and stay away from condo's as investments moving forward!
03-16-2010, 09:26 AM #136
Kinda of a crappy subject. No wonder tbere's so much crap in it.
03-17-2010, 08:44 AM #137
This situation is like working at a site that is within one local's (Union) jurisdiction, but you want to use a specific contractor that has a card from another local. So, you negotiate with the local to have a person or persons representing the local on site and they will work under the direction of your contractor. You are paying for double the manpower, but you are getting the job done the way you want it with the least amount of issues.
What you do is say yes to the HOA, then have a HVAC contractor of your choice get the permits, do the work with the HOA person assisting, and have it inspected by the city.
You explain to the "maintenance" person that you have been advised to do it this way (by whom ever you want to say, lawyer, etc.), but that he will be there and can "help" the contractor (explain to the contractor ahead of time). Add that he may get some new pointers on HVAC work that can help him with his work---you are helping him do his job better. Don't think that you will have any issues if you get him on your side.
You are paying twice, but it will be done your way and you will be able to trust the work. It's a shame the HOA is so stubborn.
Rich
04-06-2010, 02:11 PM #138
As noted at today's inspection, apparently:
04-06-2010, 03:24 PM #139
[quote=Michael Thomas;126992]As noted at today's inspection
/quote]
I don't think you even need a code reference on that one!
04-06-2010, 03:48 PM #140
Remember, papering your corner bead wipes out cracks.
04-06-2010, 03:51 PM #141
04-06-2010, 04:13 PM #142
03-24-2020, 11:02 AM #143
Re: Toilet clearance Why?
im doing my first reno and have come across this 15in toilet rule. My question is who came up with 15in and why?
03-24-2020, 11:51 AM #144
Minimum required clearance is:
- side: 15" from center of the toilet to each side
- front: 21" or 23" (I don't recall which from memory)
(I didn't notice the old date of the post I replied to ... oh well, either leave it or delete my reply.)
03-24-2020, 11:58 AM #145
[QUOTE=Jerry Peck;286511]Minimum required clearance is:
(I didn't notice the old date of the post I replied to ... oh well, either leave it or delete my reply.)[/QUOT
Thanks, what i would really like to know is why this code exists?
03-24-2020, 12:01 PM #146
My question is why your why?
It's been that for decades.
Who came up with each code requirement and why? But does it even matter?
Codes are consensus documents. An individual submits a code change, a committee debates it, the public has an opportunity for input, another committee discusses it again, then it is voted on and approved/accepted or rejected.
03-24-2020, 03:04 PM #147
Little known bogus fact. It was Jeremy Largerear who decided that it should be centered in a 30" minimum space. He was tired of having to call the fire brigade (he was from Brown Willy, a little village in Cornwall) every time he had to deposit a #2, so he lobbied Parliament to have a minimum clearance defined in the Magna Carta.
Littler known bogus fact... Largerear's best friend knew a girl who was the third cousin, twice-removed from John Crapper.
Real fact:
IRC = 15" to center, 21" from the front edge of the bowl to wall,door, or fixture.
UPC = 15" to center, 24" from the front edge to wall, door, or fixture.
03-26-2020, 07:59 AM #148
