    Apr 2008
    McKinney Texas
    Question A "how bad is it" question. Water Heater valve
    Guys, I did not find a thread on this, so here is my question. Take a look at these photos of the water heater supply valve. What is causing this and can you make an assessment as to a "how bad is it" question.
    I usually write these up to be evaluated by a licensed plumber.
    Gene
    Lee Nettnin's Avatar
    Lee Nettnin Guest
    Default Re: A "how bad is it" question. Water Heater valve
    Gene,
    Two things going on here.
    1. There is a leak at the stem, tighten the nut directly under the red handle usually will fix the problem
    2. It also appears to be leaking at the valve body, tighten the second nut under the red handle, or the gasket may need replacing.
    Lee
    New Mexico
    I think Lee's right. It happens to me sometimes when you need to shut the water off. When you turn it back on it leaks at the stem. Sometimes it fixes itself after a few days, other times it doesn't. It's usually pretty easy to fix, just a little time consuming.
    David Banks's Avatar
    David Banks Guest
    Quote Originally Posted by Gene South View Post
    Gene
    I agree with Lee but you have already evaluated it. Should be a repair item.
    Jon Randolph's Avatar
    Jon Randolph Guest
    Quote Originally Posted by Lee Nettnin View Post
    Lee
    3. It appears that the valve body itself has had past pin hole leaks that have sealed themselves up. This will not get better, only worse. No amount of seal tightening or replacement will fix the valve. More leaks will soon follow. The valve needs replaced. Look at the pictures again.
    Apr 2008
    McKinney Texas
    Thanks guys for all your input.
    Gene
    Gene,
    Its obvious that it is leaking. I always report it as a replacement item. Dont' get into telling the client "how" to repair it.
