Results 1 to 14 of 14
    Chicago IL
    Default hot water toilet
    I don't see this amenity too often but once again it popped up. Hot water line to the toilet. When I lifted the lid off the steam started coming out. It was HOT!
    I've been wondering is this a nice feeling amenity while sitting? Should I consider this for my own home? It gets awful cold up here in the winter. Anyone have one of these?
    www.aic-chicago.com
    Joshua Hardesty's Avatar
    Joshua Hardesty Guest
    Default Re: hot water toilet
    It's a nice amenity in winter until it sits for a while, the water in the bowl and tank get cold, you flush, hot water rushes in, and cracks the porcelain.
    On the other hand, they do make heated seats.
    Nolan Kienitz's Avatar
    Nolan Kienitz Guest
    You can 'steam' hotdogs in there for lunch.
    I had a 'new home final' once that had roughly 75% of all plumbing lines (hot-cold) crossed over.
    Custom home, big bucks. Should have been a 3-4 hour inspection that took about 10-hours due to all the problems that just seemed to "never stop".
    Heated water in toilets makes for a nice breeding area for germs. Not a great idea.
    Jon Randolph's Avatar
    Jon Randolph Guest
    I would think that the heat would tend to magnify any odors released.
    Ron Bibler's Avatar
    Ron Bibler Guest
    You could gets some great INFRARED IMAGING from hot water toilets.
    Good idea.
    In my experience, hot water to toilets indicates they reversed the hot and cold connections at the water heater.
    Easy to correct at single handle faucets, not so easy to correct elsewhere, such as at the toilets, hose bibbs, etc.
    It's also possible that the insulated line is now the cold water line instead of the hot water line.
    Chicago IL
    This one isn't going to be so easy to fix. The toilet is hooked up to the normal stub/shut-off coming out of the wall at the left side of the toilet.
    I should point out I found this on the reinspect.
    During the original insp the hot water tank was off. Better yet though during the org insp. There was 3/8" tubing attached to the hot water side under the vanity from a double shut-off valve. The tubing ran through the vanity, through a drilled hole in the side of the vanity over to the toilet. I noted in the report that the toilet may be hooked up to the hot water (since it appeared so) but since the hot water wasn't actually running ...
    www.aic-chicago.com
    Dennis Kloth's Avatar
    Dennis Kloth Guest
    Some people have the bright idea that this will stop the tank from sweating, Know someone who tried it, not very nice to sit on, Like a sitting on a steam bath.
    Quote Originally Posted by Joshua Hardesty View Post
    "and cracks the porcelain"
    Has been known to happen many times, and, when the next person sits down on that toilet, there is the real chance it can crack apart.
    Serious injuries have been reported from those incidents.
    Chicago IL
    Thanks for the cracking info (no pun intended). I didn't think of that, will relay to client.
    www.aic-chicago.com
    imported_John Smith's Avatar
    imported_John Smith Guest
    In Houston, our cold water in the summer gets like hot water in other parts of
    the country. Put the water heater in the attic, and we get hot water even though we are piped correctly. I always flush the toilet at least 5 times and use my infrared thermometer to get temperature. Then I compare it to the hot side of the sink and the cold side of the sink.
    In Houston, our cold water in the summer gets like hot water in other parts of the country.
    I had that at a house we owned in South Florida, with the water heater in the hall linen closet.
    The problem was they ran the hot and cold water piping (copper) through the attic, and not down low in our under the insulation.
    Both the hot and cold came out as HOT! until the lines were flushed and cooled by the hot water (yeah, the hot water cooled the hot water lines down) and the cold water.
    Instead of waiting 15 minutes for hot water, we waited 15 minutes for cool (not cold) water.
    mathew stouffer's Avatar
    mathew stouffer Guest
    It will make your wives and girlfriends happy, it will prevent shinkage.
