Results 1 to 2 of 2
05-03-2008, 11:42 AM #1
Max length of flex gas connectors
What is maximum allowed length of flexible (SST) gas (propane) connectors to water heaters and furnaces? If I read the IRC correctly, it is 3 feet for water heaters which is not a moveable appliance (oddly enough, it allows longer lines to dryers and ranges). I also don't see any IRC requirements for support of flex gas lines. The manufacturer is Dormont; they seem to specialize in commercial kitchen applications, so don't list any restrictions on residential installation. I am worried about this installation because this 6' gas line runs unsupported about 18" above floor behind the water softener - what if they had to work on the water softener and it falls over? I'd like to be able to back up my recommendation for a call to a plumber (especailly because it is a small town, so it would likely end up being the same guy that installed it in the first place)
05-03-2008, 02:43 PM #2
Re: Max length of flex gas connectors
Flexible appliance connectors should not be confused with CSST. Flex connectors can be a max of 3 ft except for ranges and domestic clothes dryers, which can be a max. of 6 ft. The intent is to allow the appliance to be pulled out for service.
Routing a flex connector behind another appliance is an improper application as this must be "piping" and not a "connector". Also, see above limits.
HTH,
Bob
