    Santa Fe, NM
    Default No - Exterior Faucets
    First time I ran across this.
    New house (2007) had no exterior faucets!!??
    Usually there are at least two hose bibs!!!
    Does plumbing code require exterior faucets?
    Charles @ PreVue Property Inspections, Santa Fe, NM
    http://www.prevuepropertyinspections.com/
    "How can someone with glasses so thick be so stupid?"
    Default Re: No - Exterior Faucets
    Quote Originally Posted by Charles Smith View Post
    Charles,
    I'm not seeing a Requirement in IRC 2003. A lot of requirements on how to but nothing on required.
    Garland, TX
    R306.5. Exterior Hose Bibs. One- and two-family dwellings shall have not less than two exterior hose bibs, sill cocks or outside hydrants with one being located on the side or rear of the structure. (Effective January 1, 2007)
    http://www.dca.state.ga.us/developme...IRC%202007.pdf
    Just another reason codes are "minimums".
