    Kevin Casey's Avatar
    Kevin Casey Guest
    Default Septic Tank Plug
    Can someone give me some info on the usual location, size, etc. of 1,000 gallon concrete septic tank plug? It'd be nice to know just what the thing looks like, how big it is (deep as well as diameter), and how prone they are to getting dislodged, sucked up, or leaking in general.
    A picture's worth a thousand words, but I can't find one.
    Thanks.
    Jon Randolph's Avatar
    Jon Randolph Guest
    Default Re: Septic Tank Plug
    Not quite sure what you are referring to. That may be why you cn't find any information. Can you further describe what you think a septic tank plug is?
    Kevin Casey Guest
    Quote Originally Posted by Jon Randolph View Post
    This site references a plug: Septic Tank Cleaning - wash-down of the septic tank during pump-out can give additional information about septic tank condition
    How to inspect Septic Tanks
    This poor fellow seems to have tried to make his own:
    October 29, 2007
    Jon Randolph Guest
    Most tanks around here are cast concrete or polypropylene (plastic) and do not have a plug like a steel tank may. I have never seen a plug, but apparently they do exist.
    As far as knocking them loose during pumping/cleaning, they do use a rake like tool to stir up the sludge on the bottom while they are pumping. I would think that this action itself could dislodge the plug.
