    JORY LANNES's Avatar
    JORY LANNES Guest
    Default FLEX GAS LINE MANIFOLD IN CHICAGO
    Hi all;
    This is my first thread as a full member.I do inspections in the Chicago Area. I came across a natural gas manifold with five flex yellow stainless steel feeds for the furnace,hot water heater,stove and fire place .Several of the flex lines exceeded 20 feet. each line had a gate valve shut off. The installation was in a 4 yr old 30 unit condo
    Has any one come across an installation like this in Chicago? Is it proper.
    Jory Lannes
    Default Re: FLEX GAS LINE MANIFOLD IN CHICAGO
    Quote Originally Posted by JORY LANNES View Post
    Hi all;
    Jory Lannes
    That is CSST with a manifold. Works fine in other parts of the country but sense Chicago does not even allow for NM wire, I have a suspicion that they might have an issue with CSST. Don't know for sure, but just guessing!
    Chicago
    Hi all;
    Jory Lannes
    Hi Jory,
    Not a problem.
    Corey
    Jory
    Hey... nice to see you are still in the business.
    We should get together for lunch sometime.
    - MDT
