Results 1 to 3 of 3
Thread: Watts TPR valve/ no drain??
06-16-2008, 05:48 PM #1
This is my first watts valve and not shure what to say, has no drain jest a gas shut off
06-16-2008, 05:53 PM #2
Re: Watts TPR valve/ no drain??
Mike,
Instead of releasing built-up pressure and temperature, those are designed to shut the gas off ... preventing the build-up of pressure and temperature.
I actually like those used in conjunction with a T&P in the top opening. The regular T&P would release any build-up of pressure and temperature while that one would shut the gas off, prohibiting any future risk.
No fuel (gas) = no heat = no danger.
06-16-2008, 06:03 PM #3
Mike
Say what it is supposed to do and call it a day. Did you go on the Watt's web site and read their material?
BTW, your dad is a friend of mine besides being a neat guy.
