Results 1 to 18 of 18
		Thread: Pex question
	09-04-2008, 07:15 PM #1 Pex question Pex questionI haven't seen much of pex yet. This is Wirsbo Aquapex
 - Any known problems with the connections used here?
 - Is it typical for the hot water side to be slightly discolored? The tubing delivering hot has an mild translucent rust-like color. (Could iron or manganese cause this - the water is not obviously high in iron).
 Thanks,
 (second image is rotated 90 degrees)
	09-04-2008, 07:34 PM #2 Re: PEX question Re: PEX questionThat is a BAD installation, starting with those "straps". The straps are supposed to "support" the PEX but not "pinch" or even cause resistance to the PEX. The PEX is required to be able to slip in its supports, to allow for expansion and contraction.
 That alone tells me that the person installing that PEX system did not: 1) know what they were doing, or, 2) did not do what they knew they should do. Their choice, but it was 1) or 2).
 PEX comes in all kinds of colors: red, blue, clear, white, milky, probably other colors too.
 The PEX coming toward you off that tee fitting is supposed to be supported before it bends away from the tee.
	09-04-2008, 07:55 PM #3 Re: Pex question Re: Pex questionPeter,
 Pex is considerable a combustible if that is a Gas appliance Vent proper clearance is required.
	09-04-2008, 08:07 PM #4 Re: Pex question Re: Pex questionHi Jerry, I have seen PEX that was distinctly red or blue, but this looks like it was clear, but discolored on the inside. You might be able to see how slightly in the second picture (although it is less distinct in the photo than first hand). RE the tight clips, I agree. It kind of looks like the installer had only the 1/2" in stock and used them on the 3/4 tubing. (?)
 Billy, good call. In this case its actually a dryer vent (which was another concern just on length - about 25' with three elbows).
	09-04-2008, 08:09 PM #5 Re: Pex question Re: Pex questionI could be wrong, but those "clips" look more like fence staples or bent over nails. Still wrong though.
	09-04-2008, 08:11 PM #6 Re: PEX question Re: PEX questionhttp://www.uponor-usa.com/~/media/Fi...spx?sc_lang=en
 This guide ( http://www.heatinghelp.com/pdfs/71.pdf ), on page 16, shows those staples, it specifically states "The tube should not be compressed by the Tube Fastener."
 The installation instructions I am looking at state "Bends within 6 inches of a connection required a tube talon or bend support (for 3/8", and 1/2" AQUAPEX). For 3/4" and 1" tubing, support is required withing 10 inches of a ProPEX connection."
 Looks like one piece in the photo is 3/4" (the closer piece) and the other piece is 1/2".
	09-04-2008, 09:37 PM #7 Re: Pex question Re: Pex questionPossible leak at the transition from PEX to copper? Noted some deterioration there?
	09-04-2008, 09:43 PM #8 Re: Pex question Re: Pex questionI've seen that same discoloration before. The discoloration was in someones dark room and nowhere else in the home. I assumed it was from the dark room chemicals.
	09-04-2008, 11:27 PM #9 Re: Pex question Re: Pex questionPeter,
 I have not noticed any noticeable color difference in hot/cold Aquapex in anything that I have inspected. It is pretty obvious in the pics you posted and it does look like rust. Could it be an old water heater or possibly galvanized nipples at the water heater inlet/outlet?
	09-05-2008, 12:30 PM #10 Re: Pex question Re: Pex questionGunnar, I believe you are on the money with the W/H or old Galvy pipes being the issue. More likely the W/H Tank is corroded and rusting out.
	09-10-2008, 01:24 PM #11 Re: Pex question Re: Pex questionGunnar is on the right track, also high iron in well water does the same.
	09-16-2008, 11:42 PM #12 Re: Pex question Re: Pex questionThose clips are the old school COPPER piping clips aren't they? There is no way I have ever seen a clip with that small of a contact surface for use with PEX.
	09-17-2008, 07:54 AM #13 Re: PEX question Re: PEX question
	09-17-2008, 09:24 AM #14 Re: Pex question Re: Pex questionJerry thanks for the reply, whose manual shows those clips as acceptable? I haven't seen those clips used on anything but copper piping here in Alberta. What do most contractors use in your location? Usually the plastic clips are used here where I am located.
	09-17-2008, 09:48 AM #15 Re: PEX question Re: PEX question
	09-17-2008, 01:44 PM #16 Re: Pex question Re: Pex questionThe clips I have seen recommended have been the tube talon type for the PEX / AquaPex piping. The warranty is void if the piping is not to MFR installation standards.
	09-17-2008, 06:58 PM #17 Re: PEX question Re: PEX questionHmm, that is for temporarily holding pex tubing to a subfloor until the floor is poured if you are reading on page 16 as you suggested. The manual you are referring is for radiant floor heating systems. My misunderstanding, I thought those photos in the first post were of a potable water supply system.
	09-17-2008, 07:27 PM #18 Re: PEX question
		No mis-understanding on your part, the photos were of potable water.My misunderstanding, I thought those photos in the first post were of a potable water supply system. Re: PEX question
 I used that because it shows those staple like straps.
 Yes, "temporarily" is the purpose, however, once the floor is poured, they become "permanent" within the poured floor.
