Results 1 to 14 of 14
    dan orourke's Avatar
    dan orourke Guest
    Default Proper terminolgy needed
    Default Re: Proper terminolgy needed
    Flange Pipe is what I've always called it. Never been taken to court for doing so.
    David Banks's Avatar
    David Banks Guest
    Smile Re: Proper terminolgy needed
    Well if thats the shower head than thats the neck
    It's called a " Shower arm"
    Brian E Kelly's Avatar
    Brian E Kelly Guest
    Around here we call it the shower arm.
    Shower Arm.....
    Richard Stanley's Avatar
    Richard Stanley Guest
    Pipe.
    David Banks Guest
    Never saw an arm connected to a head.
    Shower head arm or neck. I've heard it called both.
    It reaches out like an 'arm', however, the 'head' is mounted to the 'neck'.
    Shower arm or gooseneck. The second one might be my term, not sure.
    Tim Moreira's Avatar
    Tim Moreira Guest
    Gooseneck was my first thought.
    Thingamagiggy is my second.
    Joe Nernberg's Avatar
    Joe Nernberg Guest
    Talking Re: Proper terminolgy needed
    Shower arm.
    If you ever get stuck on terminology, walk the aisles of Home Depot, Lowes, etc. Soon afterward - you can refer to that component as a 1/2-inch x 6-inch chrome plated shower arm with an escutcheon. Impresses your friends and will make others yawn.
    Bob Stark's Avatar
    Bob Stark Guest
    ZZZZZZzzzzzzz
    Healdsburg, CA
    Looks like a very short shower arm?
