Old 05-11-2007, 04:28 PM
wayne soper's Avatar
GAS meter
I know this is wrong but is there a code as to exactly how deep you can bury your gas meter?
Home inspection
Old 05-11-2007, 05:09 PM
Bob Harper's Avatar
Re: GAS meter
NG meters are governed by the US DOT. The main thing you need to worry about is the vent on the regulator isn't blocked by ice or mud dauber wasps, the shutoff is accessible and the entire meter is accessible. Sure, above grade and not in direct contact but other than that, I wouldn't worry. For me, I'm having to worry about the CFH size of the meter for the BTU load of the house, inlet pressure, etc.
HTH
Old 05-11-2007, 05:13 PM
Re: GAS meter
Thank's Bob, So would you recommend raising the meter or allow them to dig a big hole around it, which I am sure is what they will want to do.
Old 05-11-2007, 05:50 PM
Bob Harper's Avatar
Re: GAS meter
It looks like it might have originally been above ground until they piled in the mulch. I'd recommend they clear away the crud so the shutoff and base of the meter are above ground.
BTW, did you notice what is written on top of the meter housing? Very important.
Old 05-11-2007, 06:00 PM
Re: GAS meter
Don't forget the a/c condenser unit in the right side of that photo.
  #6 (permalink)
Old 05-11-2007, 07:30 PM
Re: GAS meter
Jerry, is there a clearance to the gas meter isuue here?
Similar Threads
Gas meter location Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 1 05-07-2007 05:21 PM
rust on gas meter Jeff Eastman Plumbing System: Home Inspection and Commercial Inspection 4 04-16-2007 11:46 AM
Gas meter David Banks Heating, Ventilation, Air Conditioning (HVAC): Home Inspection and Commercial Inspection 4 04-13-2007 03:37 PM
vB.Sponsors
Ad Management by RedTyger
