LinkBack (1) Thread Tools Search this Thread
  1 links from elsewhere to this Post. Click to view. #1 (permalink)
Old 05-13-2007, 10:46 AM
Eric Shuman Eric Shuman is offline
Unknown piping.
Ran across this yesterday. Not sure what it is for. On the outside there was this configuration (photo1) and on the inside a closed loop of pvc pipe (photo 2).
Any ideas? I thought maybe a water softener hook up that is not used but I haven't seen this set-up before.
Any ideas?
Thanks,
Eric
Old 05-13-2007, 10:57 AM
Thom Walker's Avatar
Re: Unknown piping.
Is the gray line teed into the loop or is the sock just holding the open line against the loop?
- Paul Fix
Old 05-13-2007, 12:03 PM
Re: Unknown piping.
The sock is just holding the gray line crimped over and against the loop.
Thanks,
Eric
Old 05-13-2007, 12:10 PM
Re: Unknown piping.
There used to be filtration system/treatment system equipment in that room?
Old 05-13-2007, 12:13 PM
Re: Unknown piping.
That is what I was leaning towards.
Eric
  #6 (permalink)
Old 05-13-2007, 12:20 PM
Re: Unknown piping.
I think you are dead on.
- Paul Fix
  #7 (permalink)
Old 05-13-2007, 06:17 PM
Erby Crofutt's Avatar
Erby Crofutt Erby Crofutt is offline
Re: Unknown piping.
No, you're dead off.
It is a heat loop (using the ground and home heat) to keep the faucet from freezing.
OK, OK. It's just a wild thought that popped into my head when I saw the pictures.
Erby Crofutt, Georgetown, KY
B4U Close Home Inspections & Radon Testing
www.b4uclose.com www.kentuckyradon.com
  #8 (permalink)
Old 05-13-2007, 06:47 PM
Bruce Breedlove's Avatar
Bruce Breedlove Bruce Breedlove is online now
Re: Unknown piping.
Some sort of backflow preventer?
Bruce Breedlove
www.avaloninspection.com
  #9 (permalink)
Old 05-13-2007, 07:18 PM
Re: Unknown piping.
Not that wild.
That was my first thought too, some type of geo thermal heat loop, then I realized there were too many things 'not right' for that to be the case.
I had to look again and then came up with the filtration/treatment probability.
  #10 (permalink)
Old 05-13-2007, 09:41 PM
Re: Unknown piping.
Eric,
Let us know.
- Paul Fix
  #11 (permalink)
Old 05-14-2007, 06:12 PM
Re: Unknown piping.
O.K.
I inspected a one year old house today and found a very similar set-up attached to a water softening system in the garage. Photos 1-2. So back to "Dead on" I guess.
I have seen plenty of softener installs but not with this particular set-up.
This one today even had the hose bib and all just like the other.
Todays inspection also had this nice support sytem for a 65 gallon water heater and furnace/evaporator coil combo in a second floor closet! See photo 3. Needless to say, the deck they were resting on was sagging a bit.
Eric
  #12 (permalink)
Old 05-14-2007, 07:09 PM
Re: Unknown piping.
Thanks for following up.
- Paul Fix
LinkBacks (?)
LinkBack to this Thread: http://www.inspectionnews.net/home_inspection/plumbing-system-home-inspection-commercial-inspection/1046-unknown-piping.html
Posted By For Type Date
home inspection: Blogs, Photos, Videos and more on Technorati This thread Refback 05-14-2007 02:08 AM
vB.Sponsors
Ad Management by RedTyger
